2000 5.3 swap to 2008 5.3 help
I am picking up a 2008 5.3 & trans Saturday to put in my wife's 2000 Yukon. I am getting the computer and wires for the motor with it. Is this a simple plug and play or is there going to be surprises? Any help or advice is appreciated. Thanks Rod
dont think its going to be so easy. 2008s use a different type of data communication between the modules. The 2000 uses the class 2 serial data communication system and the newer ones use the gm high and low speed LAN communication system. completely different from each other. I think you are going to have all kinds of body control problems. I think you can still make it work but its going to take some research and programming. probobly not plug and play tho
you might try any of the after market harness people. i dont know off the top of my head but im sure someone on here can lead u in the right direction on this. im sure someone has done this before.
I saw the part today at the PRI Show small box with 4 plugs cam in cam out, crank in crank out. SDPC had it in their booth.You also need an extension for the knock sensors, which they have. I know I'm talking to myself (LOL) but someone may need the infor. one day. Rod
