meth sprayed through nx plate??
Old 12-10-2008, 01:50 PM
jason02Z's Avatar
Default meth sprayed through nx plate??
http://www.youtube.com/watch?v=BxaFwOPR0H8
is there anyone thats running fi use this plate set up for meth...if it could be done? it looks like it would work pretty good, but alky dosnt have the pressure of nitrous dose it..
Old 12-10-2008, 03:16 PM
DevonsZ's Avatar
i was told it needs to be around 3-4 inchs before the intake so it has time to evap. in the intake and kool the the incoming air down, with it being right at the intake it might burn as a fuel not having enough time to evap. in the air charge, but that all depends on boost level and amount of meth ur spraying, but either way it should help alot.
Old 12-11-2008, 09:00 AM
Dumb Ass Vette Moderator
ls1290's Avatar
You do want to have the nozzles a little further up stream so that it can pull as much heat out of the charge as possible. At 6300 RPMs, the air flow is pretty darn fast. Plus with the location after the throttle body, the IAT sensor is not going to read the change in temperature so you will be loosing that advantage.
Quick Reply: meth sprayed through nx plate??
