Valvetrain break in.
Old 12-10-2008, 05:25 PM
cbr600rx7's Avatar
Default Valvetrain break in.
Just as the title says. After installing a new cam and new valves do you need to brake the parts in slow to prevent damage? Also when braking in other parts such as a turbo or lower rotating assembly is it better to use a none synthetic oil to allow the parts to wear properly?
Old 12-10-2008, 05:57 PM
ls1leadfoot's Avatar
i was told to NOT use synthetic on the break in.....
i eventually never switched back either....have a melling with the high spring in it running castrol 10w40 never less than 45-50 psi over 50 at wot
Old 12-10-2008, 07:35 PM
DONAIMIAN's Avatar
I believe there's a topic on this in the advanced section. The thread had a lot of useful information.
Old 12-10-2008, 08:59 PM
SOMbitch's Avatar
It's a roller cam so drive it like there are blue lights behind you
Totally different than the old sbc tappet cams........
Old 12-10-2008, 09:06 PM
SPRAYED 01's Avatar
I just give it a couple hours of really easy driving. Then let it sit untill its totally cold. I believe after one heat cycle you are good to go. I think if anything needs break in its the valve springs.
Old 12-10-2008, 09:49 PM
transAm-98's Avatar
It's hydraulic roller so heat cycle it if you want and then let er rip. My whole new motor had a total of 2 miles on it before we thrashed it on the dyno.
Old 12-11-2008, 02:22 AM
cbr600rx7's Avatar
You dont by chance have the link to that do you. I did a search and could not find it.
Old 12-11-2008, 07:43 AM
03Sssnake's Avatar
Yep After a heat cycle or two, the valve springs should be good to go.
