Widest drag radial on a Trans am?
Old 12-10-2008, 11:23 PM
Prost79c's Avatar
Default Widest drag radial on a Trans am?
Like my other post i am going with a new set of wheels on my TA. I would like to know what the widest Drag Radial I can put on it is, if the Summit star wheels come in a 15x10 to fit my car. If not then a 15x8. Thanks
Old 12-11-2008, 12:54 AM
sillz's Avatar
I have a camaro but pretty much same thing with 15x10 running a 325/50/15 backspacing is 7.5 Hope this helps
Old 12-11-2008, 06:26 AM
2000WS6ICK's Avatar
275/50R-15 on a 15x10 Weld Pro Star Wheel with 7.5" backspacing is what I run.
Old 12-11-2008, 07:55 AM
DopdBrd's Avatar
If you are looking at the Summit Stars then you only have one option, 15x8 with a 5.5BS. Now for tires you can run a 275/50R15 with no modding whatsoever and the tire is just very VERY slightly taller than stock (.3-.4 inches). If you want to go with a bigger tire a 275/60R15 is a 28" tall tire that will fit on your 8" rim.
The 275/60 will have a slightly smaller contact patch then the 275/50 so the 275/50 will look wider.
Old 12-11-2008, 08:07 AM
Prost79c's Avatar
On the 325/50x15 how much BFH did you have to do? it looks like the 325 is almost 2 inches wider total, and 1.5 to the ground?
Quick Reply: Widest drag radial on a Trans am?
