which cam to use with patriot stage 3 heads
looking to get around 500 hp to the ground when its all said and done but need some advice on which cam to use with the stage 3 patriot heads. want an aggressive cam with great numbers but thats not over aggressive for driving purposes. i have other parts for project but need help picking the cam.
anybody have a proven setup with stage 3 patriot heads and cam?
With the right combination...G5X3, MS3, MS4, LSR 54-460-11, VRX6, SI6, SI7 can get you there or close while retaining driveability, but if you want to be sure get a custom spec from Patrick G.
FMS F13 will get you there if you have trick items like dry sump, ITB's, otherwise you will need bigger like an F15.
What are the specs on those heads?
