Running stock head bolts vs studs so its a safety net?
Old 12-11-2008, 10:50 AM
z28mccrory's Avatar
Default Running stock head bolts vs studs so its a safety net?
Im ordering the final little odds and ends for my mild turbo build.
I was curious if anyone uses GM head bolts instead of studs. I would rather blow a head gasket than mess something else up. If someone would go wrong.. wastegate stick... etc... i would rather pop a head gasket than mess up the motor.
500-550rwhp is the goal on 8psi or so. Motor is going to be a complete 98 longblock with new ring, bearing, and arp rod bolts.
Old 12-11-2008, 10:53 AM
cjg454ss's Avatar
ah get the studs, using the head gaskets as a safety wont really work. do it once and do it right, i dont think anyone in here is running stock head bolts. most go to studs, few go to arp bolts.
Old 12-11-2008, 01:42 PM
Gingervitis Addict
slow67's Avatar
When the gasket goes, it can take out a block or a head or both. Get the studs.
Old 12-12-2008, 10:34 PM
camarols1's Avatar
Ditto.
It might fly on an iron setup, but aluminum heads don't care for gasket failures much.
Old 12-12-2008, 11:39 PM
Gingervitis Addict
slow67's Avatar
Originally Posted by camarols1
Ditto.
I wouldn't even do it on iron....seen a blown head gasket take out an iron block (wore a groove between cylinders on a SBC).
Old 12-13-2008, 12:03 AM
black98ws6ta's Avatar
The piston is going to melt before anything else gets hurt, make sure the tune-up is nice.
Old 12-13-2008, 12:49 AM
1989k1500's Avatar
You'll be fine with 500rwhp. Just get the studs. IMO
Old 12-13-2008, 08:30 AM
EPP
EPP's Avatar
Head bolts can also pull the threads out of the block when installing them, which is another good reason to use head studs. Bob
Old 12-13-2008, 08:58 AM
lsxlowtech's Avatar
I have a set of pre-03 ARP head studs I will sell for 165.00 shipped to your door!! PM me if you are interested. thanks JC
Old 12-13-2008, 09:30 AM
TS6
TS6's Avatar
Why aren't you replacing the pistons while its apart?
Old 12-13-2008, 01:47 PM
z28mccrory's Avatar
This is a budget build bud. If the motor didn't have so many miles on it i would just run it as-is. For my power goals i dont think i need to do that. I was well above my power goals back in the day on my camaro, and it was a nitrous car. It lasted for 50k miles like that, and when i finally pulled the motor apart it still looked like new.
Old 12-13-2008, 05:28 PM
TS6
TS6's Avatar
Yeah but those pistons are fragile, it might be worth checking the classifieds for a nice used set. Well worth the $$$.
Old 12-13-2008, 08:56 PM
z28mccrory's Avatar
Yeah i know... just keeps snowballing though.
At first i was just like "Well i will just throw this kit on the stock motor and have some fun for a while".... then i figured that i may as well give it a quick freshen up. Then i added ARP rod bolts... then LS6 springs... etc. I know its all very worth the money, but a simple goal is turning more and more expensive.
I know that is money was no issue that pistons would be a great investment... but my goal is to just have some fun with the stock motor for a year or so... then go back and do rods and pistons and crank it up.
Old 12-14-2008, 10:47 PM
Restricted User
Lawnboy's Avatar
NA build it right , forged diamond pistons eagle H-beam rods , use your stock crank and your done > o yeah new oil pump and double roller timming chain set , SLP has a combo kit that works well
goodluck
Old 12-15-2008, 05:34 AM
SStolen's Avatar
I sent you a PM with the number to my tuner. He is the man and has his own dyno. He'll make sure it's right and safe. Good luck.
