Anything i need to do special to install Moser 12bolt?
Other than having the bearings pressed in. Do i need to slide the backing plates on before they are installed?
any tips/tricks are MOST welcome!!!
T is for Towing not Turbo
Re: Anything i need to do special to install Moser 12bolt?
you most definitely must have the backing plates on the axles before you press the bearings on. believe me, i know, lol. other than that, from my experience so far, if you got 4.11's, get earplugs which yoke did you get? the 1310 or 1350? if you got the 1310, you'll be good to go with the driveshaft, if you got the 1350, you need a different u-joint for your drive shaft. loctite on the torque arm bolts is good too. other than that, not a lot else, good luck,
Brian
Brian
