Drastically Reduced TTP Heads/Cam Package Prices Till Jan 15th
To be a part of the special, you will have to secure a deposit with us before January 15th, 2009.
TTP Equalizer Heads/Cam Packages
- Livernois Stage 2 "243" Casting Heads, Assembled with Dual Springs, Titanium Retainers, Valve Seals, Seats
- TTP Custom Camshaft
- Trickflow Hardened Chromemoly Pushrod Set
- LSx Heavy Duty Single Roller Timing Chain
- Melling 10296 High Volume Oil Pump
- ARP Head Bolts
- GM Lifter Set
- GM Master Heads/Cam Gasket Set
- Royal Purple 5w30 Synthetic Oil Change
- GM Dexcool Coolant
- Installation of all Parts
- Full Custom Dyno Tune - Includes Dyno Time
$4499.95 Retail
$3699.95 Sale Price
Power levels with a good flowing longtube headers + catback ranges from 425-445rwhp/400-415rwtq.
** This package does not include injectors. Please inquire about injectors, when performing the base heads/cam package we should be able to utilize stock injectors. When upgrading to our Punisher cams, LSx intakes, or other power mods aftermarket injectors may be necessary.
TTP Trickflow Heads/Cam
Trick Flow GenX CNC Ported 215cc Cylinder Heads
Harland Sharp Rocker Arm Set (1.7 Non Adj)
TTP Custom Camshaft
Trickflow Hardened Chromemoly Pushrods
Trick Flow 42lb Injectors
Melling Select High Volume Oil Pump
LS2 Heavy Duty Timing Chain
ARP Head Bolts
GM Lifter Set
Royal Purple Synthetic Oil Change
GM Dexcool Coolant
$6999.95 Retail
$5699.95 Sale Price
Installed Options:
Add Hypertech 160/180* Thermostat (Stock Water Pump): $50
Add Meziere Electric Water Pump (With Thermostat, 30amp relay + wiring): $800
Add LSx 92mm Intake Full Port-Matched: $1075
Call For Specific Throttle Body Pricing If Needed
All prices above includes all LSx FBodies, C5/C6s, GTOs, CTS-Vs, Trailblazer SS's. Special packages available for G8 & other AFM vehicles.
We will require a 75% deposit up front to secure the parts. Please allow 1 week for parts delivery. Turnaround time on the vehicle is 3 days turn-key.
973 256 1234
- ARP Head Bolts
- GM Lifter Set
$4499.95 Retail
$3699.95 Sale Price
TTP Custom Camshaft
ARP Head Bolts
GM Lifter Set
GM Dexcool Coolant
$6999.95 Retail
$5699.95 Sale Price
Installed Options:
973 256 1234
