Wheels & Tires - What size spacer to fit Cray wheels on an F-body
Rowdy94
12-12-2008, 03:32 PM
I love both of these wheels for the price...The Cray Manta and Scorpion. There isn't a lot available in 19x10.5 that is affordable.
What size spacer is needed to fit these on an f-body?
It's a 19x10.5 wheel with 65mm offset, and I want them on both the front and rear.
My thinking is 1/2" for the spacer. That would make the 65mm offset wheel into a 53mm offset wheel, correct?
Rowdy94
02-11-2009, 06:41 PM
Did anybody have an answer for this? I'd still like to know...
Rowdy94
02-14-2009, 09:50 AM
dontmeSS
02-14-2009, 10:12 AM
I as well would like an answer to this. I went to my local Discount Tire to purchase the Cray Manta wheels in 18x9 for the front and 18x10.5 for the rear. I was told they would fit perfect and they would install them, just takes a few weeks to order (not in stock).
Is there a spacer needed for the rear?? These are great rims and looking to purchase ASAP
'Trust'
02-14-2009, 01:41 PM
Unless I'm thinking backwards a 1/2" spacer make it a 78.3mm offset and they'll stick out even more.
EDIT: However, 10mm isn't big at all so they would probably fit decently with a 65mm offset.
Donohue96M6Z28
02-14-2009, 01:49 PM
Ya man, you're thinking backwards. A spacer will lower the offset, not raise it. (Lower the offset - pushs the wheel outwards, higher the offset -pushs the wheel inwards)
99Bluz28
02-15-2009, 01:54 AM
What you need is a set of 20mm H&R spacers, which will give your wheels a +45 offset!:nod:
http://store.allsprings.com/shared/StoreFront/default.asp?CS=allsprings&StoreType=BtoC&Count1=528469264&Count2=445609688
