If you tune the airflow model to be correct, and your commanding what you want in the PE table, you should be fine.
if you rape the PE table, instead of tuning correctly, most likely it will not work correctly.
Ryan
airflow model as in my maf airflow?
I tweeked my maf airflow and VE tables till my Fuel trims are in check ( between -4 and 0)
now I'm doing my PE table. is that correct?
I'm new to hptuners, just learning as I go, thanks for the imput
