8.5:1, 408 compression test. What readings should I expect?
Old 12-12-2008, 10:30 PM
AVB
AVB's Avatar
Default 8.5:1, 408 compression test. What readings should I expect?
I posted this in the LS1 section but thought I'd post a link here since it's on a forged low compression motor. It's a 408 on 8.5:1 and have started seeing more blowby lately. I've done the leak down which showed near identical #'s across the cylinders and so I'm now gonna do a compression test to see if it shows anything.
What #'s should I see for good compression and what would suggest needing new rings?
Old 12-13-2008, 11:39 AM
AVB
AVB's Avatar
I got 160-162 and #8 came up w/ a 158. Any thoughts/comments on these #'s? If it makes a difference, this is the cam I run.
Cam Motion 236/232 dur. @.50" .588/.574 114LSA 110ICL
Leak-down numbers were consistent too.
Old 12-13-2008, 12:28 PM
MBFAN's Avatar
They should all be within 3%-5% of each other.
Seems a bit low to me for a fresh motor, but I'm kinda used to only checking my NA race motor, which had over 240 in every cylinder. My 1994 GMC Sonoma with 240K on it when I bought it had around 150 in each.
Old 12-13-2008, 03:13 PM
xLBx's Avatar
AVB, what kit are you planning to run now ?
Old 12-13-2008, 03:29 PM
Gingervitis Addict
slow67's Avatar
That much cam with that low of compression = low cranking compression. I actually calculate ~150 psi.
Old 12-13-2008, 03:41 PM
AVB
AVB's Avatar
Looking for one... considering everything
Old 12-13-2008, 08:56 PM
xLBx's Avatar
After christmas you should find a killer deal on the parts. Good luck bro !
Quick Reply: 8.5:1, 408 compression test. What readings should I expect?
