ms3 on f.i setup
ms3 on f.i setup
is anyone running an ms3 on an f.i setup and if so are there any down side cause i thinking about using the ms3 for my current na motor in my turbo build.
I would say go with something smaller. This topic has come up many times but is not the best cam for FI, not say it won't work. But the overlap on a MS3 is a bit much and something like a 228/228 or a 232/232 would be alot better. The 232 is still a bit big in my honest opinion, but to each their own.
Your guage wont show as much "boost", but the air flow and power will still be there. I would try it especially if you will be staying with the stock compression. I also just noticed you're running a 6.0 so the extra cubes will help with spooling that turbo.
