What torque for the 2 middle head studs on a warhawk block? how much is the stud off?
Old 12-13-2008, 05:51 PM
BigRich954RR's Avatar
Default What torque for the 2 middle head studs on a warhawk block? how much is the stud off?
On the warhawk engine block how much do you torque the head studs to? Most important what is the torque for the added studs ?
All 5 heads studs are in the same spot as the iron lsx block but the intake side middle head stud right?
Where is that middle stud compare to the lsx block ? Just moved 1/4 (?) of a inch to the center of the block but still in line with the lsx pattern?
Can some one lay a LSX head gasket over a Warhawk head gasket and post a pic so i would be able to see
Old 12-14-2008, 08:53 PM
any one ?
Old 12-15-2008, 12:16 PM
BLNLS1/RX7's Avatar
You need to call Bob at Exotic Performance Plus.
Old 12-16-2008, 01:59 PM
ssswagon's Avatar
I had mine torqed to 75ftlbs - same as the other 4 studs.
You should be torquing your heads to the same amount as your machinist did when he torque plate honed your bores.
Old 12-16-2008, 02:11 PM
7 Second Club
Phil99vette's Avatar
The torque spec is based on the fastener size and material used.
Quick Reply: What torque for the 2 middle head studs on a warhawk block? how much is the stud off?
