Fueling & Injection - Best methanol injection system??
ayousef
12-14-2008, 03:01 PM
Not trying to start a fight or anything, im simply looking for the most advanced meth system available.
Something that can be triggered by both RPM AND throttleposition for example.
Something with a big enough tank not to run out in 3 races
etc...
PS.
questions on what to run in the meth tank. Is obvious some would argue 50 meth, 50 water. But what if i tell you my friend has been running mineral bottled water in his vette for the past year, and he drives it daily. A friend of mine told me that a small meth tank costs $400 here in Dubai and it will most likely run out in 5 races.
My purpose is to increase my octane rating and make use of cooling the IAT's.
Suggestions would be appreciated, im also searching while I get some answers.
405HP_Z06
12-14-2008, 03:18 PM
http://www.alcoholinjectionsystems.com/index.html
Funkybird
12-14-2008, 03:31 PM
I have the AIS stage 2 kit and love it. I run 100% meth and have only filled the tank twice since I got it in August.
AFASTYZFR1
12-14-2008, 05:18 PM
Alkycontrol
OUTLAWZ RACING
12-14-2008, 06:41 PM
I use the snow stg three with the boost refernce on board no issues with it. I dont know if it would work on rpm base but it will work on tps .
tomz28
12-17-2008, 01:37 PM
i have a coolmist set up here but most of the ones i have look at all have abou the same thing going on. its all about what you like and how much you want to spend
618HAWK
12-17-2008, 01:51 PM
Cooling mist.....with the "Vari Cool Controller" Yes it dose cost a bit more but gives you plenty of operating options.
BigRich954RR
12-21-2008, 11:02 PM
Alkycontrol
Alkycontrol I believe is one of the best systems
I would run pure meth more cooling power/ higher rise in octane/can make more power on it.
With a good kit you can run any tanks size you want.
I dont live there so i have no idea how much meth cost per gal there. But cant see it being 400 a small tank. Its about 5 dollars a gal here
If its really hot there i can see running a mixes of 50/50 to keep the meth from boiling in the tank. but pure water is not the best way to go.
Its can last for months or days no way to know till you tune it and how much you need to keep temps and knocking down.
WHY do you want it trigger by rpm or tps ?
digitalsolo
12-23-2008, 12:44 PM
Call Julio at Alkycontrol. They have a great kit and probably the best customer service I've had with any company, period. I have a 3 and a 5 gallon tank for my car, and run 100% meth.
crf538
12-23-2008, 07:46 PM
+1 for Alkycontrol
jomomma
12-23-2008, 08:33 PM
im running an alkycontrol kit on my c10 with no complaints. julio is very knowledgable
navymitch12
12-23-2008, 08:36 PM
the new snow performance stage 3 seems to have the most inputs to control the alcky inputs.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
