Can a stock rear swaybar fit behind the Dana S60?
Hey folks, I've got a 2000 Z28 and just picked up a Dana for it. Will the stock swaybar fit behind it for now until I decide on which larger bar to go with? Its a daily driver H/C/I/N2O car with occassional track use (once the Dana gets put on) I don't want to go with a dedicated drag bar, but figure I will probably want an upgrade to get more acceptable 60' times.
Also, when people swap these rear ends into their cars, do you just go ahead and paint the entire thing or just the mounting points and center section to prevent them from rusting? Its got an aluminum T/A cover so I don't want to paint that because it looks pretty good, but should I paint the axle tubes too? Thanks
LS1Tech Premium Sponsor
Hello, we offer a sway bar kit for aftermarket rear ends. Here is a link to our site.
http://www.bmrfabrication.com/
