cam/heads help
cam/heads help
I recently did a engine swap in my 99 trans am from ls1 to an ls6 right now i have long tubes to true duals, 373 and a tune... i want to do heads and cam but im not sure what is a good combo and what other supporting mods i should do such as injectors etc. i want to go with a pretty aggressive cam. please help thanks
Internet Mechanic
A cam swap often is around 800-1k, you should upgrade to at least a LS6 intake which is 300-350 and ported heads can be had for little over 1k and then add the dyno tune, it can be done but it's TIGHT.
As for combos, go to the dyno section and start combing through.
Also think about what the intended use of the car.
Furthermore with the m6, you need to consider the rear if at the track, it has a whole different kettle of fish to race that car and even if it has Drag radials and suspension, its either will light up the tires or bog and possibly break the rear.
I guess you need to decide what the intended use.
