Injector help!!!
Old 12-15-2008, 07:18 PM
Z28Camaro30Ann's Avatar
Default Injector help!!!
I have a 97 LT1 SS Camaro. AFR Heads, Cam, rebuilt block bored 30 over, tune, MSD ignition, Adjustable fuel pressure regulator, ram air intake, and cat free exhaust...I am looking at installing a supercharger next and re-enforcing my rear end with a Ford. I have stock injectors in this thing right now. I am looking to upgrade. I was thinking Ford 30# because I know on GM fuel pressure they pump out 36#...Is that sufficient for a supercharger, and if so will they fit on a 97 LT1 properly???
Old 12-15-2008, 07:23 PM
StealthFormula's Avatar
Yes they will fit and they are more like 32-33# on an LT1 I believe. The SVO 30's would probaly be fine now depending on size of cam and work done to heads but they definetly won't be enough for when you go with forced induction.
Old 12-15-2008, 07:24 PM
ok so what is recommended for me when I get the super then?
Old 12-15-2008, 08:34 PM
strokin93z's Avatar
just go with like a 60# and tune accordingly. Fuel injector-><-Your engine. heh
Old 12-16-2008, 07:44 AM
multmigs's Avatar
anyone know the best/cheapest place to buy new injectors??
Old 12-16-2008, 07:52 AM
DAVE00's Avatar
Minimum 42# for your setup and upto 60#. Do a search as there is a chart on here or CZ28.com that gives HP - injector size reccs based on your hp estimate at the FW.
Old 12-17-2008, 02:03 AM
robsquikz28's Avatar
x2 ^ i agree
Quick Reply: Injector help!!!
