oil pump
The LS6 oil pump is now the stock replacement for the LS1 and it is an upgrade over the old LS1 pumps. Porting one is easy and just takes a little time. Katech sells a shim to increase pressure or you can use washers, etc.... If you don't want to port, an out of the box LS6 pump is plenty adequate.
FOR YOUR INFORMATION, here's a document I assembled showing how to port an LS6 oil pump: Download
