So who makes a DS loop for a TD x-pipe
Old 12-16-2008, 04:43 PM
AChotrod's Avatar
Default So who makes a DS loop for a TD x-pipe
I need to know if there is anyone making a DS safety loop that will work with a True Dual set up with a X-pipe???
Thanks a ton
Mike
Old 12-16-2008, 04:48 PM
LS1TECH Sponsor
Joey@Tick's Avatar
Spohn's will work - I ran it with my TSP True Duals.
http://www.tick-performance.com/cata...y/chassis/#dsl
Old 12-16-2008, 04:54 PM
AChotrod's Avatar
Sweet Thats exacty what I was looking for!!!! Thanks!!!!
Old 12-16-2008, 05:13 PM
toothdoc's Avatar
Does that one go on without dropping the driveshaft?
Old 12-16-2008, 05:44 PM
AChotrod's Avatar
Looks like it would. But taking out the DS is so easy, even a caveman can do it!!
Old 12-16-2008, 06:14 PM
SmokedOutZ28's Avatar
Do you have pictures of it installed with the true duals?
Old 12-16-2008, 06:36 PM
quickta's Avatar
Default safety loop
I have the TSP true duals on my '00 WS6 and tried a Lakewood safety loop and it didn't fit, the Spohn safety loop looks like its built the same as the Lakewood
Old 12-17-2008, 09:01 AM
Low N Slow's Avatar
I don't have TD but I have the Jegs loop and it tucks up really tight. Only about $40 too.
Old 12-17-2008, 10:01 AM
AChotrod's Avatar
What exactly didnt fit?? Usually TDs dont tuck up at all and that the Lakewood and Jegs DS loop look pretty flat across the bottom?
Old 12-17-2008, 02:35 PM
StealthFormula's Avatar
I'd like to know as well because I really need to get one.
Old 12-17-2008, 02:49 PM
BlackBADaSS02's Avatar
I had the Lakewood DS loop and TSP TD's, and it fit without any problems.
Old 12-17-2008, 03:20 PM
67camaro's Avatar
I think these guys offer a few different options:
http://www.midwestchassis.com/
Old 12-17-2008, 10:17 PM
quickta's Avatar
Default safety loop
here is a picture of my exhaust and could not get the Lakewood on, where it comes out from the mounts it hits the pipes
Old 12-17-2008, 10:40 PM
quickta's Avatar
Default safety loop
another picture, does any one else TSP true duals exhaust look like this, could it be to close and not letting the safety loop to go on
Old 12-18-2008, 10:54 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
i do have a crossmember with a loop specific to the TSP duals. it is designed for the tunnel mounted torque arm that we manufacture. i will soon be releasing a tunnel form fitting loop for just about any configuration that should work for everybody.
Old 12-18-2008, 08:53 PM
quickta's Avatar
Default safety loop
I will definitely get a tunnel form fitting loop when you get it ready, pm me it you can when it is ready, by chance what will it run
Quick Reply: So who makes a DS loop for a TD x-pipe
