Suspension & Brakes - suspension issue
View Full Version : suspension issue
redhot lt-1
12-16-2008, 07:37 PM
i just replaced a thorq arm on a 98 trans am for a friend of mine his broke at the axle housing. before it rode like a wagon and ot cut the bolt heads and flangs for the u joints but not bad but the owner wants to replace it, before putting the car down off the lift i looked around the suspension and didn`t see any other issues. but it still ride like a wagon i feel the spring my have been damaged but unsure i will be putting it on the lift again on thurs. but looking for any ideas of what to look for other than the springs.:bang:
JD_AMG
12-17-2008, 06:30 AM
Way too vague.
Does he have any other aftermarket suspension? Bushings? Wheels/tires? What are the tire pressures set at?
If all else is is good working order I have my money on shocks.
redhot lt-1
12-17-2008, 10:11 AM
the suspension is totaly stock with stock wheels and tire size the shocks were replaced about a year ago he said but i see what your are saying if the axle rotated enuff it could have bent the shock tube binding up the movement.thanks i`ll let you know
Sam Strano
12-17-2008, 12:30 PM
He didn't hurt the springs, but breaking TA's does often break shocks. It's not good when a shock is connected to the axle and body and when the TA breaks the axle rotates, but the shock can't rotate as far. Things bend like shock shafts.....
redhot lt-1
12-22-2008, 05:05 PM
thanks sam you where right i pulled the shocks and they were bent like "C" put new ones in and she rolling. thanks again for your`s and JD AMG`s help.
redhotlt1
Sam Strano
12-22-2008, 05:12 PM
It happens occassionally...
01CaMMMaro
12-22-2008, 06:56 PM
witness of another Stranoman happening.
