New Products Showcase Come inside to see the newest hardware!
58x to 24x reluctor wheel electronic adapter module
Old 12-16-2008, 09:55 PM
LS1Tech Sponsor
Jason Haines @ LPE's Avatar
Default 58x to 24x reluctor wheel electronic adapter module
Lingenfelter Performance Engineering recently announced the availability of our 58x to 24x reluctor wheel/trigger wheel electronic adapter module for all GM Gen III V8 (LS1, LS6, LQ4, LQ9 etc.) and early Gen IV V8 equipped vehicles.
The Lingenfelter TRG-001 module allows Gen IV GM V8 engines with the 58x crankshaft trigger or reluctor wheel and the 4x camshaft timing gear to be installed in earlier vehicles designed to accept the 24x crankshaft trigger wheel and the 1x camshaft trigger wheel without having to take the engine apart to change the cam timing gear or the crankshaft reluctor wheel.
The Lingenfelter TRG-001 is a plug-and-play" design that connects directly to your existing wiring harness and to the factory engine sensors. No additional wiring for the conversion module is needed except on some early Gen IV V8 engine equipped vehicles that will need a camshaft sensor extension harness.
Click here for a link to the installation instructions/detailed product description.
Old 12-17-2008, 07:30 AM
Brent@LPE's Avatar
Sweet product Jason.
Should save a lot of time if someone makes a mistake or wants to retrofit,
Brent
Old 12-17-2008, 04:17 PM
LS1Tech Sponsor
Mike@Diablosport's Avatar
Awesome, glad to see this is available.
Good job guys.
Old 01-13-2009, 04:32 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
this should sell well
Old 01-13-2009, 04:48 PM
dlove's Avatar
Mine works great!
Quick Reply: 58x to 24x reluctor wheel electronic adapter module
