98 camaro starting issue.
I am new to the LS1 crowd and need some help with a starting issue. With the cold weather we have had here in San Antonio on cold starts it revs to around 2500-3000 RPM and slowly drops to around 500 and almost stalls. It is a 98 camaro SS M6. I searched and found that this could be caused by leaking intake gaskets. If this is the case wouldn't it also set a fault for a lean condition? Thanks in advance for you input.
