Wheels & Tires - Best F/R Pressure On The Street
ss346ci
12-17-2008, 12:26 AM
I have a 2000 SS with 275/40zr17 kumho ecsta asx tires all around on the stock 17x9 ZR1s, and after taking a wheel/tire combo to hibdon's for a flat repair, I noticed that the rears are both wearing more in the center signaling an overinflated condition. I run all four corners at 30psi as per the gm sticker. What's the best rear pressure for the street?
Bird Man
12-17-2008, 08:14 AM
They shouldn't be wearing in the middle at that pressure.
kdavis
12-17-2008, 09:57 AM
i keep a little more pressure in the front than the rear, due to the front haveing more weight on the tires.
ss346ci
12-17-2008, 11:20 AM
I think that the F/R weight balance on our cars is 57/43 or 58/42 so that would require less air pressure in the rear tires than the front. Since 30 psi has delivered even wear in the front, I expect that less pressure would deliver the best results in the rear.
cookba
12-17-2008, 03:14 PM
i have ran 32 front and 30 rear on my KDW tires the past 2 years with no issue. I think my next tires i will try 32 front and 28 rear.
Xsta Z 28
12-18-2008, 08:55 AM
32 ish . . .
NC01TA
12-18-2008, 10:09 AM
No way should there be a problem at 30 psi. Get a new quality tire gauge and see the probable difference. Some cheap gauges can be way off.
ss346ci
12-18-2008, 11:07 AM
I have a "quality" camel tire gauge and I have tried a snap on gauge at my dads shop which corresponded with my dial gauge. With almost 60% of the 3500 lbs over the front axle, the rear tires will definately need a few psi less to wear evenly. I'm just going to mark tht top of the tread with chalk and alter pressure until the wear is even across the tread surface.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
