help with Y-pipe
Old 12-17-2008, 12:32 PM
djjab57's Avatar
Default help with Y-pipe
hey guys i just bought the Jet hot long tubes with emissions and the ends have the 3 bolt flanges, i live in Texas so i will be keeping my cat as i have to do a sniff test every year. my question is for the people running cats, what y-pipe are ya ll using. i cant find one with just one cat, i see some that have two but my car came with one cat so i believe that is all i need to put back on it. is there a preferred ORY that you can put a cat on. any help would be great thanks in advance
Old 12-17-2008, 12:51 PM
Elliott's94Z's Avatar
http://speed-eng.com/store/jet-hot-y...dy-p-3627.html
Old 12-17-2008, 12:58 PM
djjab57's Avatar
thanks, i have seen this one at the WS6 store but i was under the impression it was an off road pipe. on this web site it says it can be used with stock exaust. so looks like i have my answer
Old 12-17-2008, 01:02 PM
AChotrod's Avatar
just weld in one into the ory y pipe
Old 12-17-2008, 01:32 PM
djjab57's Avatar
will welding on the jet hot coating hurt it or will i have to grind it off first
Old 12-17-2008, 01:38 PM
camerory's Avatar
For welding you have to get down to the bare metal for good penatration. Usually using a wire brush on the part after the coating is chipped away to get the surface really clean.
Quick Reply: help with Y-pipe
