Can Pontiac update the ecm/tcm
Old 12-17-2008, 12:41 PM
cderry's Avatar
Default Can Pontiac update the ecm/tcm
Can pontiac update the computer to newer specs. I have an 06 gp gxp and I have heard that the 07 & 08 gxps have in the dic the actual tire pressure of each tire showning? In the 05 & 06 it just warns you if any one of your tires is 10psi lower or higher since you last rest the tire pressure monitor. I'm assuming that the sensors are their since it knows if the pressure is 10psi hi or low.
Old 12-17-2008, 06:13 PM
cherrygxp's Avatar
no update will make the DIC show the tire pressures. maybe if you buy a DIC out of a newer GXP and then update it.
Quick Reply: Can Pontiac update the ecm/tcm
