Need a Turbo timing table to get me started.
Can anyone share some of your input on this? I have no meth and run 93 octane only, I have a JGS 50mm WG and they say the least boost it will make with the softest spring is about 9 PSI so I want to be conservative. I'm using HP Tuners and have never tuned a turbo car so I welcome any and all advice,TIA.
On the hptuners site you have some turbo cars that you can take a timing table off of.
I went around 12 max for starters and obviously you want to be able to monitor knock retard like a hawk as you gradually move up on the timing.Obviously you want to also get your afr more turbo friendly like 10.5 to 11.5 range. You are using a maf for now?
OK, so i am not a expert at tunning. I just started and feel i got the basic's down. This is from my maf tune, @ 6 psi, on 93 octane. Ended up staying @ 11.3 afr, and didn't pull any timing. I paid to have this tune done. Now i just changed the os to 2 bar sd. I have pulled timing out for now to get the afr's correct, then i will throw some timing back at it, but atleast you can see roughly what was done. Again im not 100% sure if this is the best way to do it, but this is what i had done by what i feel was a pretty good tuner.
This was on a 98 so my table doesn't go as high as yours.
If the pictures is not big enough, here is the link
http://www.sidewayz.net/sparktable.jpg
Hope this helps, it can be hard getting started but once you get some basics down it all makes sense, and comes together.
Chris
Chris
Chris
Chris
