485hp slp package
485hp slp package
I just wanted to know if anyone tried it yet and what you guys think of it. Here is a link if you have not seen it. slp 485hp package
Re: 485hp slp package
yes I think those are flywheel numbers. I don't know what percent these cars lose through the drivetrain. I was told my last car lost 22 or 23%.
Milled 63.5cc combustion chambers raise compression ratio to 10.7:
I am no expert but if you mill out a CC wouldn't that remove material effectively lowering compression. Milled heads maybe
I think that the cam alone would benefit any LS1 engine. The heads are CNC'ed so I would bet that any of the ----> sponsers CNC'ed heads would be "roughly" the same. With most CNC'ed heads out there I would be concerned with cost before their numbers, b/c there are limitations with CNC'ing. This could be why hand ported cost more, just my .02
SLP numbers are always flywheel cause it makes it look like it puts out tons of power. Although with the camshaft they are using I dont doubt that package would put 400 to the rear wheels.
Marco
Marco
