whats the difference between ls1 and ls6 heads?
Old 09-28-2003, 12:32 AM
pdd
pdd's Avatar
Default whats the difference between ls1 and ls6 heads?
if i was to buy say MTI ls6 heads, would they work on my ls1??
Old 09-28-2003, 12:36 AM
Beast96Z's Avatar
Default Re: whats the difference between ls1 and ls6 heads?
Yes, they are a direct bolt on. LS-6's have larger runners and a diffrent exaust port design.
Old 09-28-2003, 12:49 AM
blk~2000~Z28's Avatar
LS6 heads have basically the same ports as the 6.0L truck heads but the CC is smaller giving it a compression advantage w/o milling them. Yes you could buy LS6 heads for a stock LS1 but you would want or possibly need everything from LT's, an intake and definently a cam to take full advantage of those heads. Otherwise it would effectively be overkill to buy LS6 heads w/o some of those other mods in mind.
Old 09-28-2003, 11:38 AM
pdd
pdd's Avatar
my car(2000 vette) has the flp LT, intake and a tr224.so im definatly lookin into heads next. so it looks like stage 2 ls6 heads are the way to go
Old 09-28-2003, 12:23 PM
SNAXS's Avatar
Of course they would and your car will haul *** more also.
