a couple of simple questions
Old 12-18-2008, 09:33 AM
93TAJ.C.'s Avatar
Default a couple of simple questions
I'm getting pacesetter longtubes and I'm not sure weather to get the coated ones or not, is it worth the extra money? Also, what kind of numbers will i be able to see by doing a loyd elliot cam (228/235 .560/.560 109 LSA.), cold air, long tubes, elec. water pump, and pcmforless tune? Block and heads are stock for now because of money shortage.But i have to pull the motor this weekend to do a pan and front cover gasket so I thought I might as well give it an overhaul.(main and rod bearings, opti, water pump, plugs and wires, clutch, and all the other stuff)
All advise is greatly appreciated!!
Old 12-18-2008, 09:42 AM
the_merv's Avatar
I would get the Coated ones.
Old 12-18-2008, 09:57 AM
baylove's Avatar
i agree with the merv on the coated headers thats what i have looks good and it does keep the under hood temp down compared to the non painted headers worth every penny if you havent contacted lloyd he can give you alot of info on your build alot of people have said good things about him and his work
telephone: (972) 617-5671
Email: nighttrain66@msn.com
Old 12-18-2008, 12:18 PM
93TAJ.C.'s Avatar
thanks, so with coated headers and all the other mods what do you think an estimated rwhp would be, i have the t-56 and stock gears with 26" wheels for now.
Old 12-18-2008, 01:01 PM
robsquikz28's Avatar
either way i have the coated headers and know of many others who have these headers and they still rust anyway.......pacesetter uses a shitty coat job id imagine....either way if all else is stock on ur engine with all supporting mods and that cam easy low to mid 12
Old 12-18-2008, 01:43 PM
the_merv's Avatar
The Pace Setters I have are pretty good..just because they are a lower price than most doesn't mean they are shitty.
Quick Reply: a couple of simple questions
