New Products Showcase - New Pick up Tube girdle for LSX engine from BRP Hotrods
BRPhotrods
12-18-2008, 02:18 PM
BRP Hot Rods is proud to introduce the oil pan girdle for the 00+ GM oil pickup tubes (Patent Pending). This is designed for any pickup tube that has the tab attached to the tube. It has been tested on LH8, CTS-V, Truck and 00+ F-Body oil pans without any issues. Anyone who has changed the oil pan on a LS engine knows how easy it is to pinch the O-Ring and cause a pressure leak in the motor. All GM oil pumps feature two mounting bolts but only use one in all OEM applications. This simple girdle slides over the pickup tube to allow for a secure seal of the o-ring. Getting a solid seal on the pick up tube ensures adequate oil pressure when initially cranking the LS engine and through the engines life.
http://i281.photobucket.com/albums/kk209/BRPHotRods/o3.jpg
http://i281.photobucket.com/albums/kk209/BRPHotRods/o2.jpg
http://i281.photobucket.com/albums/kk209/BRPHotRods/o1.jpg
Shown is the OEM tab seal being broken with a ball point pin. This simple girdle could save your motors life for only 19.95.
http://i281.photobucket.com/albums/kk209/BRPHotRods/oem.jpg
Kit includes the BRP oil girdle with aircraft grade bolts and washers.
http://i281.photobucket.com/albums/kk209/BRPHotRods/kit.jpg
Call BRP for more info the first batch will be available by the end of December
www.BRPhotrods.com
770-751-0687
BRPhotrods
12-22-2008, 10:37 AM
6mX20
Zinc Hex
Flanged bolts (not in pic but will be in all production kits.)
8.8 grade
Contrast vibration protections in cast iron
BRPhotrods
01-29-2009, 02:55 PM
We have updated the design and all girdles now shipped with a curved lip for clearance with the timing chains and covers.
Here is a photo, early girdles might need slight smoothing to fit.
http://i281.photobucket.com/albums/kk209/BRPHotRods/IMG_0003.jpg
http://i281.photobucket.com/albums/kk209/BRPHotRods/IMG_0005.jpg
