ordered a set of heads :-)
Old 12-19-2008, 01:26 AM
deuce_454's Avatar
Default ordered a set of heads :-)
I finally pulled the trigger on a set of heads, after much deliberation and looking at threads here the choice fell on a set of TEA LS6 stg 2 heads.. the cam is a patrick G grind thats 226/232 .609/.604 111LSA+2 headers are stainless works long tubes and the exhaust is an x-piped true dual 3 inch magnaflow. the intake is an ls6 for now.. ill be throwing on an edelbrock when its released (the car is a 79 malibu so it should fit)
tranny is A4 with pro torque converter and compushift electronics, so it will be at lockup most of the time... rear is a moser 12 bolt and im hoping for 430 rwhp before the intake swap...
Old 12-19-2008, 01:45 AM
letsrunem's Avatar
Okay.. Wife sick of hearing about it?
Old 12-19-2008, 03:20 AM
deuce_454's Avatar
LOOOOL you are right on the mark there letsrunem.... she is a goos sport though, every week or two she will take part in whatever nonsense im doing in the shop... sort tools, clean, make coffee.. give a hand or two if im pulling an engine or whatever...
