Idle rpm for California smog test
Old 12-19-2008, 02:27 AM
WS6 RULES's Avatar
Question Idle rpm for California smog test
Does anyone know the allowed idle rpm for California smog test? I want to set it as high as I can with out going over the limit which will cause a fail. Thank you for any help.
Old 12-19-2008, 03:19 AM
ZMONSTER!'s Avatar
I was wondering about this the other night too. You have a hotcam though what are you worried about? I passed with my 224/228.
Old 12-19-2008, 10:54 AM
12secSS's Avatar
From my last test, they only do 15 MPH and 25 MPH tailpipe testing. Setting your idle as high as possible is not going to do anything to pass the test, just make them think you have a vacuum leak. Also the ECM will control the idle rpm to the programmed value, if you alter the set screw then it will throw a TPS code, which results in a failed test.
Old 12-19-2008, 11:29 AM
ZMONSTER!'s Avatar
They tested mine at idle, but I passed. Tuning the car to idle at a certain RPM may very well be an option.
Old 12-19-2008, 11:44 AM
12secSS's Avatar
If they did, as mine was a while ago, then they would check to ensure the idle RPM is within spec.
A4 = 550-650 or so
M6 = 800-900 or so
Old 12-19-2008, 12:53 PM
WS6 RULES's Avatar
I think the 114 LSA helped you. Mine is 112. I was trying to hide the choppy idle.
Old 12-19-2008, 12:57 PM
WS6 RULES's Avatar
I tune with EFILive. Idle speeds are programmed.
Quick Reply: Idle rpm for California smog test
