My S80 truck manifold kit
Old 12-19-2008, 04:41 PM
B18CYA's Avatar
Default My S80 truck manifold kit
Been lurking around here for two years now collecting parts for my build. Probably time to get to work!!
ENGINE
lq4 bore .005
eagle 4" crank
eagle rods l19 bolts
wiesco pistons
total seal rings with stainless top ring
arp head and main studs
patriot stage III 317
va speed cam
texas speed ported ls6 oil pump
double roller timing chain
ls6 intake
ENGINE MANAGEMENT
bs3
TURBO KIT
S80 purchased from forced induction 2/07 very dusty
all stainless hot side piping including flanges
turbo smart 48mm progate
ebay intercooler
4" dp
some pics
Old 12-19-2008, 05:02 PM
Josh@KY-Turbo's Avatar
Nice looking layout.
Old 12-19-2008, 05:11 PM
B18CYA's Avatar
thanks wanted to leave plenty of room to work on the car and keep it easy to tear the kit down if need be
more pics
Old 12-19-2008, 05:30 PM
What front k-member setup are you running to squeeze the 4" DP trough?
Old 12-19-2008, 06:38 PM
frcefed98's Avatar
Nice placement of the turbo, similar to Kyle's (NA$TY-TA) seems like there is a ton of room too.
Old 12-19-2008, 07:39 PM
RealQuick's Avatar
Nice!
Old 12-19-2008, 07:48 PM
B18CYA's Avatar
bmr turbo k member. but its not ideal if you plan on running the dp next block... like me. heres a pic of a piece of 4" through it judge for your self
Old 12-19-2008, 08:09 PM
LS1Tech Sponsor
Superman09's Avatar
maybe i'm mistaken but isnt the point of the turbo k-member to give more room on the other side of the motor mount pedestal than the side you have it? Either way, looks great so far!
Edit: Nevermind, i read your words along with the picture
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old 12-19-2008, 08:57 PM
LS1TECH Sponsor
DrTurbo's Avatar
Very nice. Should be a STOUT car.....let us know if you need anything else!!
Old 12-19-2008, 09:04 PM
eviltwin_1987's Avatar
what radiator fans are those?
Old 12-20-2008, 02:44 PM
B18CYA's Avatar
thanks might be calling about upgrading to a 88 and a race cover. this was originally for a 347 then went iron then to a 4" crank...
Old 12-20-2008, 04:03 PM
B18CYA's Avatar
summit part FLX-210 2500 cfm puller
Old 12-20-2008, 05:39 PM
venom ws7's Avatar
Nice build man good luck with the rest of it should be a mean SOB.
Old 12-22-2008, 11:19 AM
LS1TECH Sponsor
DrTurbo's Avatar
Old 12-22-2008, 12:03 PM
BlazinT/A's Avatar
why are you running the dp next to the block instead of in the pocket of the kmember?
Old 12-22-2008, 01:03 PM
SPRAYED 01's Avatar
Do you know what part # that fan setup it? I need some really slim dual fan setup for my new kit and that looks great!!
Old 12-22-2008, 01:48 PM
frcefed98's Avatar
Old 12-23-2008, 09:15 AM
B18CYA's Avatar
got some 4" radius 4" yesterday. going to remake the down pipe and these will definitely help
4" next to 6" radius
Old 12-23-2008, 09:17 AM
B18CYA's Avatar
wont fit with truck mani's. thats why I say its not the best with truck manifolds
Old 12-23-2008, 10:47 AM
BlazinT/A's Avatar
o thanks good to know
Quick Reply: My S80 truck manifold kit
