Line Lock Activation
How are you guys activating your line locks? I am going to put a master arm switch on my nitrous switch panel in front of my shifter, but I need a momentary switch to actually ACTIVATE it.
Where are you guys putting your momentary switches at? I have a Hurst T handle with button off my old car but don't know if I want to use that. I have seen a momentary mounted right in front of the shifter with nitrous switches but how easy is that to hold down while you are doing a burnout or getting ready to launch?
I am in the same boat as you but thinking of running dual master switches or just 1. I don't know of any tracks that actually check those so I think you will be fine if you just want to use one switch. I just think it is more of a safety issue on the street?? I am thinking about putting the 2nd switch in the ashtray so that way it could not be accidently activated.
See I had a line lock on my old bird. I loved it and had that and my two step hooked up to my hurst t handle. It worked great. I could do a burnout without the line lock, flip a switch and activate the two step, put it to the wood and go. As soon as I let go of the button the line lock released, the two step deactivated, and the spray hit. It was pretty much like a stalled auto on juice coming out of the hole.
I just don't know if I like the way the t handle looks and dont want to take off my pretty MBA ****, LOL
Here is how i did it:
It's the fog switch on the right. I just realized that you have 96, so this post probably won't help you out at all. When activated, the light shines up. Turn it off and it's good to go.
I have the SLP kit. I went down to Ace hardware and paid $5 for a momentary switch. I mounted it inside my console, in front of the CD storage area. When I go to use it, I raise the lid, hold down the switch, etc. Not using it, lid is closed, it can't be seen or activated.
