Wiring Sail Subs in Camaro
Old 12-20-2008, 06:21 PM
Huggerorange73's Avatar
Default Wiring Sail Subs in Camaro
Hey,
I just received the KEE audio replacement speaker package for my 99 Camaro with the Monsoon system.
The Bazooka speaker says it's 4 ohms....I thought I read on here that the Camaro sub is 2 ohms.
Before I install these, I assume that the subs have to be wired on each speaker in parallel to get to the factory 2 ohm spec?
The rest of the install seems pretty painless.....
Thanks in advance for the help!
Old 12-21-2008, 10:03 PM
KEE AUDIO's Avatar
Hi, I addressed this awhile back but it was on another post. Check out post #7 for the actual diagram (for this it is the top left diagram specifically). They are DVC 4ohm so you just wire them in parallel. Takes about 5 minutes and 12" of speaker wire, 6" for each side if that. Hope this helps you!!
https://ls1tech.com/forums/stereo-el...ack-stock.html
Old 12-21-2008, 10:26 PM
I did find that diagram, I just wanted to verify that info before I wire it up....the package looks sweet...can't wait to throw it in!
Thanks for the help!
