Summit Universal X-Pipe Kits
Old 12-20-2008, 08:10 PM
Black96Z's Avatar
Default Summit Universal X-Pipe Kits
How difficult would it be to install a Summit® Universal X-Pipe Kits on a camaro with pacesetter lt headers?
http://store.summitracing.com/partde...5&autoview=sku
or
Old 12-20-2008, 08:13 PM
3rdgen92maro's Avatar
the links dont work man. but anyways its not hard at all man. i have pacesetter LTs with a summit 3in xpipe kit on my car. heres a few pics of it while i was welding it up. it tucks up pretty good for a 3in setup. I dont have any of it on the car at the moment tho
Old 12-20-2008, 08:47 PM
Black96Z's Avatar
links fixed. Did you have to do any cutting? How much?
Old 12-20-2008, 08:54 PM
StealthFormula's Avatar
Wasn't at all hard for the shop that did it for me. It took them a good 4 hours or so to do it but it was done perfectly. Required some bending, cutting, and welding, something I wouldn't personally do without the right tools and know-how but it can be done.
Old 12-20-2008, 08:56 PM
Elliott's94Z's Avatar
Looks as good as it sounds too bro
I'm looking at that same one from Summit.
Old 12-20-2008, 08:57 PM
Thanks brotha now GET IT!
Old 12-20-2008, 08:59 PM
Revelation Z28's Avatar
i would put some single chambers on it. thats what i planned on doing before.
Old 12-20-2008, 09:02 PM
Black96Z's Avatar
That looks NICE!
Old 12-20-2008, 09:07 PM
Originally Posted by Black96Z
That looks NICE!
Thank you! I think you would be very pleased with the kit, works real well for me and many others.
Old 12-21-2008, 10:33 AM
ks my ss's Avatar
i have done quite a few x-pipe setups with the summit and jegs uni kits. i always tuck the mufflers in as close as i can to the drive shaft and torque arm and suck them way up to the body. the above looks good but not as far in as i like and you loose ground clearence. on all the ones i have done the lowest part is always the collectors.
it takes me about 3 hrs to do a setup with no lift. a lift would save a ton of time.
Old 12-21-2008, 10:40 AM
tspence45's Avatar
http://videos.streetfire.net/video/9...ust_192864.htm
In the video, I still hadn't had my mufflers moved. They were just hanging too low there. So, I took it back a couple months ago and had it ran like this. Sorry the underside of the car is kinda dirty. I didn't really have much of a choice of driving it in the snow last week.
Old 12-21-2008, 12:45 PM
zlicious94's Avatar
Ya having an x pipe is the best!! Music to the ears at all times
Old 12-21-2008, 12:47 PM
Bowtie_Aaron's Avatar
here is the universal Jegs kit on my chevelle..
aaron
Old 12-21-2008, 07:52 PM
Counted Out's Avatar
How much did the install cost?
Old 12-21-2008, 08:01 PM
Wasn't cheap...Cost me $568 which included labor plus the turndowns, paint, hangers, brake clean etc. Typically its not that high but the place I took it too is an expensive shop but I knew it would be done right.
Old 12-21-2008, 08:11 PM
I second that on my boy's set up
I think I might actually be louder then you finally with my LE set up Find out here soon!
Old 12-21-2008, 08:42 PM
luckyou03's Avatar
here is my summit xpipe kit and pacesetters:
Old 12-21-2008, 09:05 PM
^^^ nice!
Old 12-21-2008, 09:12 PM
tspence45's Avatar
Man, that's pretty high. I had them do my LT header install, fab the x, bought piping from them to take out the back, and they also put my plugs and wires on. It only cost me $300. It would've only been $200, but they had too many difficulties taking off my old Edelbrock TES shorties. Then, I also didn't have much ground clearance. So, I had to take it back and have them move the mufflers and bend all new piping after the x, and they also painted it all black. But, that was still only another $120.
Old 12-21-2008, 09:25 PM
davidadavila's Avatar
if youknow how to weld easy i got mine from jegs they were a little cheaper at the time
Quick Reply: Summit Universal X-Pipe Kits
