LT1 won't turn over
LT1 won't turn over
My 97 TA won't start. I drove it to the store....came out and it wouldn't turn over. The funny thing is...when I turn on the ignition, no dash warning lights come on (like they usually do before you crank it over). Everything else is working fine. Jumping it has no effect. It seems like the whole ignition system is dead (although the radio, heater, windows, etc work).
Any idea???
Any idea???
Great, thanks for the info...it gives me a starting point to look for the problem. I have the factory service manuals, and for the life of me I can't find the diagnostic section for this type of problem.
Thanks again, and I'll report back on what I find.
-Rich
-Rich
Take the lower panel off and reach in and jiggle the connectors on the ignition switch. If they have heat damage, they may not be making a good connection. It's very common for the main power feed wire to get a bit overheated. The switch is a common failure point, as well.
Very well could be a bad ignition switch or the connector to it. Info for replacement.
Where do you get this? I am assuming it's a dealer part?
Again, thanks SO much!!!
-Rich
Dealer or AC-Delco seller can provide the pigtail. Alternately, you can try scraping the contact in the connector and trying to rebend it to restore some spring to it, so that it will try to hold more tightly.
Cool, glad we could help. I unfortunately never seem to get that lucky. It is always a stupid wire or a glitch in the matrix.....that can't be seen found or fixed. Might have to go to a wrecking yard for that pigtail.
The connector came in today, and I installed it. Nice solid connection to the new ignition switch, and no matter how much I wiggle the wires, it stays connected.
Thanks a million folks!
-Rich
-Rich
