"How To" R&R Gears
Old 12-21-2008, 03:55 PM
frankmarroquin's Avatar
Default "How To" R&R Gears
By anychance does anyone have a "how to" or "write up" with some pics? I have a 98ss with a A4 with the stock 3:23's and I am upgrading to Richmond 3:73's. If anyone could direct me that would be cool. Also what would seals and bearing would i need to rebuild my rear end. Thanks guys
Old 12-21-2008, 10:00 PM
There, read and I found it.... Thanks LS1Tech
If anyone else was intrested here is the site... http://www.keliente.com/gears1.htm
Old 12-22-2008, 10:50 AM
Jawsgear's Avatar
We also have a full downloadable installation manual on our website that we helped write for Yukon Gear. I do not car for the gears much these days but the installation manual is about as detailed as you can get. Just click on the link and there will be a downloadable link on the page. Any questions let me know.
http://www.jawsgear.com/tech_kits.php
Jeff
Old 01-08-2009, 03:45 PM
camaroracer91's Avatar
how long does this take for someone with not much experience, and is it do able for a rookie?
Old 01-08-2009, 04:30 PM
BJM
BJM's Avatar
Check my sig, my write up is a bit different, it highlights the things that can go wrong. My housing was not suitable for a swap assuming that the factory pinion was good enough. I had to play a lot with the shimming.
Old 01-08-2009, 06:57 PM
green28's Avatar
How long does an install usually take, including replacing bearings?
subscribing for all of the install links.
Old 01-08-2009, 07:54 PM
BJM
BJM's Avatar
Some people seem to do it insanely fast. I had to make tools and do a lot of set ups before my gears were done. It took me around 20 hours the second time but I took my time to do it right.
