View Poll Results: what would you rather have wet or dry nos
wet
26
96.30%
dry
1
3.70%
Voters: 27. You may not vote on this poll
what would u rather have wet or dry
Old 12-21-2008, 05:25 PM
screming_z28_95's Avatar
Default what would u rather have wet or dry
im thinking i wanna change the dry shot of nos i got to a wet shot is there really ne diffrences
Old 12-21-2008, 06:35 PM
3rdgen92maro's Avatar
the only real diff is that the wet shot is gonna pull fuel from the fuel rail when your on bottle opposed to the dry shot that relies on the MAF to add fuel.
Old 12-21-2008, 09:23 PM
LT1PwrdZ's Avatar
WELL ... I have had both. My dry kit was simple and very awesome. My wet kit hit a ton harder. I enjoyed both kits. If i did it again, It would be a Wet shot. Here are the two kits i have used.
Dry-- http://store.summitracing.com/partde...5&autoview=sku
Wet-- http://store.summitracing.com/partde...5&autoview=sku
Old 12-21-2008, 11:28 PM
mondojackal's Avatar
wet. it's safer cause you don't have to worry about the MAF adding the extra fuel. also, you don't have to worry about the stock injectors maxing out, because there is no extra load placed on them.
plus....you can run a bigger shot.
Old 12-23-2008, 12:11 AM
In-Zane Moderator
ZONES89RS's Avatar
The choice is clear on that one.
Old 12-23-2008, 03:45 AM
bombebomb's Avatar
Wet, from all the info iv read.
Old 12-23-2008, 07:12 AM
Phantom's Avatar
Simple...the same way I like my p*ssy
Old 12-23-2008, 10:20 AM
ryle's Avatar
UMMMM.... What were we just talking about the other night??? I already did the research for ya, cause I'm thinkin about a shot.... WET
Old 12-23-2008, 10:33 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
Originally Posted by 3rdgen92maro
the dry shot relies on the MAF to add fuel.
LT1 Dry kits do not use the MAF for fueling...they bleed a portion of the nitrous flow to the fuel pressure regulator....this will drastically increase the fuel pressure therefore forcing more fuel through the injectors with each pulse.
Old 12-23-2008, 04:49 PM
Cross's Avatar
I know I am buying a Wet Kit setup for 100 to 150 Max for my DD 355. I would not consider a Dry but thats just me.
Old 12-23-2008, 07:02 PM
1996camaross's Avatar
wet is the only way
