Automatic Transmission - Grinding
View Full Version : Grinding
4THGENCAMAROFAN
12-21-2008, 09:36 PM
Car is a 95 3800(not sure which trany the automatic was). Intermittent grining. Sometimes when you drive the car it's perfectly fine other times it constantly grinds...even in neutral.
What's going on here guys???? Please don't tell me I need a new trans. Also has an rpm flair on the 2 to 3 shift.
performabuilt
12-22-2008, 12:47 AM
Well I would try the manual section first, But would be hard to diagnosis with out hearing and feeling it
4THGENCAMAROFAN
12-22-2008, 08:33 PM
Why the manual section????
4THGENCAMAROFAN
12-22-2008, 08:34 PM
Ok a new addition to the problem. My car will accelerate when you push the pedal in neutral. What in the f*cking hell??????????????? My car is f*ckin weird.
BobDoLe
12-23-2008, 01:25 AM
if the car is accelerating in neutral and its not the transmission, it must be possessed...
so i'd take it to a tranny shop or exorcist - pick your poison.
Camaro396
12-23-2008, 01:34 AM
Your post is all sorts of confusing. Do you have a Auto or a Manual? One section you say Auto, then you mention a clutch???????????
4THGENCAMAROFAN
12-23-2008, 01:35 AM
so i'd take it to a tranny shop or exorcist - pick your poison.My dad said that it's normal for auto cars to do that when it's really cold like it is here.
twitchtwice
12-23-2008, 06:35 AM
i think he's young and isnt sure how a transmission works.
4THGENCAMAROFAN
12-23-2008, 11:02 AM
i think he's young and isnt sure how a transmission works.You're right....absolutely cluelss as how an automatic transmission works.
4THGENCAMAROFAN
12-23-2008, 11:07 AM
Your post is all sorts of confusing. Do you have a Auto or a Manual? One section you say Auto, then you mention a clutch???????????The car is an automatic...I mention clutch because automatics have clutches too, not just manuals.
I'm thinking the clutch might be bad becuase it has an RPM flair on the 2-3 shift when driven hard, indicating that the clutch could be worn out and not engaging into third gear quick enough causing the rpms to flair up.
Camaro396
12-23-2008, 12:28 PM
I believe your confused on how an automatic transmission works. They do not have "a clutch" they have clutch packs, but I think your confused on how they work.
4THGENCAMAROFAN
12-23-2008, 12:46 PM
I believe your confused on how an automatic transmission works. They do not have "a clutch" they have clutch packs, but I think your confused on how they work.well that's what i was reffering to was the clutch packs. I just said clutch for short.
4THGENCAMAROFAN
12-23-2008, 07:15 PM
Any other info guys???? I'm absolutely clueless on auto transmission(don't know a lot about manuals either).
