NXL work with a Nasty or Speed Inc. fuel rail?????
I was wondering if the NXL would work with an aftermarket fuel rail?
I was thinking about trying an NXL sometime in the future and I was wondering if it would work with one. If not I would probably try a TNT DP or maybe a NX DP. Not a big fan of the nos products.... besides the 5177 kit.
Josh S.
Josh S.
Re: NXL work with a Nasty or Speed Inc. fuel rail?????
Well, the NXL system includes a high-flow fuel rail, but has the stock size/configuration fuel inlet from the stock line. I'm betting you could pretty easily put AN fittings on the NXL rails as well, if you already had big lines brought up front. So it'd be feasable to use the NXL rails instead of another manufacturer's rails if you were going to do a fuel system and direct-port nitrous.
ohh..... I don't guess I got a good undertanding of how the kit works. I thaught that the rail worked kind of like a distrobution block..... my fault.
Josh S.
Josh S.
