ALL NEW Precision Race Components .700" Xtreme Lift Spring kit!
Guys we just received the first production of all new PRC .700" Xtreme Lift double springs! This combo is designed for people wanting more spring pressures for L92/LS7 valves, or looking for additional lift past the standard 1.291" springs .660" configuration.
This all new spring features a 1.351" OD which will not fit a standard spring pocket, but with only slight modifications these springs will install & still leave plenty of clearance for most ports!
The all new spring kit will be available with a spring pocket cutter for guys interested in cutting the spring pockets locally, or we offer the service on any of our PRC cylinder heads FREE OF CHARGE!!!
Link to site:
http://www.texas-speed.com/shop/item...d=997&catid=48
Here's a few of the new springs specs:
Specs:
MAX. OUTSIDE DIAMETER 1.351"
MAXIMUM NET LIFT @ 1.850" I.H. .700"
LOAD 1 (L1=1.850 in) 160
LOAD 2 (L2=1.150in) 460
This spring will be the perfect answer to all the guys pushing the limits of valve control with the aggressive lobes & heavier valves. The LS7 / L92 guys don't have to worry about heavy valve control anymore!
This all new spring should allow budget minded consumers to purchase 400cfm LS7 heads from PRC for low $2000 range! This should bring 600rwhp stroker prices even more reasonable! Look for a LS7 head 420cid LS3 engine with stainless valves on the engine dyno here very shortly! We're shooting for a 700hp street engine that everyone can afford!
Link to site:
Specs:
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
LS1 Tech Administrator
This will be great for guys wanting to run those fancy new .367" Comp lobes with LS7 heads (giving .661" lift) or many of the other high lift lobes. I'm keeping this in mind. Good stuff!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
The standard spring easily handles the MS4 & Torquer 3 camshaft. These springs are designed for bigger lift or heavy valves that need help with valve control.
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
These would be great for shimming in extra seat pressure in a forced induction application, looks like you could have 200# on the seat with .100 of shim? Have to see if theres enough money left for these.
Are you going to sell the springs alone?
LS1Tech Premium Sponsor
The $499 does not include the tool. These springs do require a different retainer than our standard dual spring kit, and will not work with anyone else's retainer that we've found so far. So, buying the springs alone wouldn't do much good for you I am afraid.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
I change my springs every 2 years. I already have two different sets of retainers. Before I buy a third set I want to know the (approx) price I will be paying for replacement springs in two years when I change them.
Its a shame (to my knowledge) there isnt a spring that uses the 1.4x od retainer thats works on our cars in high lift applications.
Gotcha! The single springs will run about $20 each when you're ready to replace them.
__________________
