All New PRC .700" Lift Xtreme Lift Spring Kit Info!!
Guys we just received the first production of all new PRC .700" Xtreme Lift double springs! This combo is designed for people wanting more spring pressures for L92/LS7 valves, or looking for additional lift past the standard 1.291" springs .660" configuration.
This all new spring features a 1.351" OD which will not fit a standard spring pocket, but with only slight modifications these springs will install & still leave plenty of clearance for most ports!
The all new spring kit will be available with a spring pocket cutter for guys interested in cutting the spring pockets locally, or we offer the service on any of our PRC cylinder heads FREE OF CHARGE!!!
Link to site:
http://www.texas-speed.com/shop/item...d=997&catid=48
Here's a few of the new springs specs:
Specs:
MAX. OUTSIDE DIAMETER 1.351"
MAXIMUM NET LIFT @ 1.850" I.H. .700"
LOAD 1 (L1=1.850 in) 160
LOAD 2 (L2=1.150in) 460
This spring will be the perfect answer to all the guys pushing the limits of valve control with the aggressive lobes & heavier valves. The LS7 / L92 guys don't have to worry about heavy valve control anymore!
This all new spring should allow budget minded consumers to purchase 400cfm LS7 heads from PRC for low $2000 range! This should bring 600rwhp stroker prices even more reasonable! Look for a LS7 head 420cid LS3 engine with stainless valves on the engine dyno here very shortly! We're shooting for a 700hp street engine that everyone can afford!
Link to site:
Specs:
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
They look good. A few questions:
Spring questions:
Retainer questions:
Seat questions:
Thanks!
Spring questions:
- What material are the springs made of?
- Is the spring treated in any way to improve endurance? e.g. Nitride, cryo treat, etc.
- What is the I.D. of the outer spring?
- What is the I.D. of the inner spring?
- How much does the spring weigh?
- What is the spring coil bind height?
- What is the spring free length?
- What is the spring rate?
Retainer questions:
- How much does the retainer weigh?
- Does the retainer offer additional installed height? e.g. +.050, etc?
- Do the retainers use standard LS 7 degree valve locks?
Seat questions:
- In the picture the spring seats look titanium; what material are they made of?
- How thick is the spring seat?
Thanks!
Race your car!
Nice option for a good price.
Ever look @ coming up with a better option for the guys that are runnign a 1.55 diameter spring, something that could take the place of a crane 9989, without going to solid roller spring rates?
I'm finding that these thigns don't generally last all that long, and have been replacing them once a season which has been adequate, but I'd like to get something on there that's a little more beefy, maybe with a little more spring pressure, something that would retain it's initial pressure a little longer would be nice.
Aaron I can get you most of those specs in the am!
JL this is my last spring for a little while, that large of a spring wouldn't be to much of a big seller for us, we built this one to help control l92 & ls7 valves
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
LS1Tech Premium Sponsor
Spring questions:
Retainer questions:
Seat questions:
Thanks!
Spring questions:
- Is the spring treated in any way to improve endurance? e.g. Nitride, cryo treat, etc. Polished
- What is the I.D. of the outer spring? .994"
- What is the I.D. of the inner spring?.726"
- How much does the spring weigh? .194
- What is the spring coil bind height? 1.100"
- What is the spring free length? 2.433"
Retainer questions:
- Do the retainers use standard LS 7 degree valve locks? yes
Seat questions:
- In the picture the spring seats look titanium; what material are they made of? Same as every other seat out there, regular steel.
- How thick is the spring seat? .045"
Thanks!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
