Air Lid Question
Air Lid Question
I removed my egr and air systems, and now i have a hole in the side of my lid. I need some ideas to tasefully cover the quarter sized hole. As of right now, i have an attractive piece of duct tape there. LOL. any ideas appreciated
Go to your local hardware store & look for a plastic plug or other. Should be a cheap flat plastic plug that works. You may have to experiment. If necessary, buy something larger & drill it out to fit.
FYI, I've done this with a couple lids that I've painted for projects for the 1998-2000 models that don't require it. Simply add a small bead of silicone to help seal it up if necessary.
If fact, that's what SLP does when you buy a lid these days. They send a plug with it just in case you don't use the AIR porthole.
