vic jr. vs LS6 intake
Old 12-23-2008, 08:02 AM
deuce_454's Avatar
Default vic jr. vs LS6 intake
ive been looking at a buncs of threads here and it seems like the consesnus id that a stock TB ls6 intake is alittle low on potential compared to FAST and spiders... my combo is a 226/232 .609/.604 111+2LS ans TEA LS6 stage 2 heads.. the car is a 79 malibu so i dont have cowl or height issues like a 4-gen..
i have seen people gain big running vic. jr's and 4500 style TB's over elbows.. and TPIS has a dyno comparo where the vic is up over the LS6 in lower Tq and over the FAST 90 in higher RPM Hp...
other than having to run a SD tune... is installing vic-jr a good idea+??? or should i go for the tunnel ram style edelbrock intake.... or si there simoly no gains over an LS6 intake????
Old 12-23-2008, 08:14 AM
PowerTalk's Avatar
Think you need to get a cam grind to suit to max the potential of em
Old 12-23-2008, 04:01 PM
deuce_454's Avatar
hmmm that might be true to get the best cam for that intake... but im wondering if swapping to that intake will be beneficial for my setup...
Old 12-23-2008, 04:50 PM
AznMuscle's Avatar
That intake is normally for spinning up high. What do you shift at? This a drag car? Non the less, having one in that car would make it just look cooler, even if the performance isn't there.
Old 12-23-2008, 05:42 PM
deuce_454's Avatar
that is a very good point....
Old 12-23-2008, 05:55 PM
StreetStalkerZ's Avatar
I just put one on mine this past weekend. You have to realize that this is pretty much a drag racers intake. This intake will outshine a fast 90 or 92 up top but lose a bit of torque down low during daily driving.
My shift points are at 7100 rpms so it fits perfect for me and i may have to move it up a tad after swaping to this intake. I personally don't care about the "lose of tq down low" because when i flash the converter off the line im never under 5700rpms going down the track. My cam will work very well with the Victor jr intake but i don't advise people to run it unless you have the cubic inch to handle and a tuner willing to spend alot of time tuning on it.
23x/24x .605/.613 108 *2 degrees advance
