Kyle finished up the 2009 LTX Shootout website!
Old 12-23-2008, 08:39 AM
Tony Shepherd's Avatar
Default Kyle finished up the 2009 LTX Shootout website!
Kyle stayed up late into the night to finish up. He did an outstanding job once again. Please pin this site as a favorite so you can check updates...etc. Registration will be open soon and also event sponsorship opportunities.
http://www.ltxshootout.com/2009/index.php
Old 12-23-2008, 08:53 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
nice
Old 12-23-2008, 09:06 AM
94Z28rag's Avatar
Sweeet.
Old 12-23-2008, 09:30 AM
riceburnerZ28's Avatar
looks good !
Old 12-23-2008, 11:59 AM
LS1 SPEED's Avatar
good deal
Old 12-23-2008, 12:56 PM
hashtagBMW
Speed Density's Avatar
Niice!
Old 12-23-2008, 01:13 PM
Cross's Avatar
Hmm the last two classes look like I might have a chance to enjoy we shall have to see.
Old 12-23-2008, 02:28 PM
Moderator
BizZzatch350's Avatar
Site looks really great!
Old 12-23-2008, 07:09 PM
FASTFATBOY's Avatar
Looks good, But I have yet to figure out the performance advantage of a minitub. If the specified tire is on the car for that class, who cares if its minitubbed?
Old 12-23-2008, 08:35 PM
foggedz's Avatar
Penalty for a carb?
Old 12-24-2008, 09:17 AM
Z-RATED94's Avatar
I too wonder about that. Another is no Lexan. If your meeting the weight requirement, what's the difference? The only reason I mention this is, the Percy's back window replacement looks like a good way to drop a few pounds, just like the minitubs. No disrespect intended, just curious.
Old 12-24-2008, 03:58 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
there is no penalty for mini-tubs, but they are not allowed in Extreme-Street
Originally Posted by foggedz
Penalty for a carb?
this is due to the increase in operating RPM over a stock PCM
This was a highly debated issue and it was settled on leaving the OEM laminated windshield for safety reasons.
Old 12-24-2008, 04:44 PM
FASTFATBOY's Avatar
LTX Extreme N/A (Naturally Aspirated)
Must have LT1-based engine. No power adders permitted. Heads must retain the factory 23 deg valve angle. Only stock/stock ported intakes will be allowed. Welded intakes not permitted. LT1 PCM only. Must retain opti spark. Coil per plug allowed. DOT approved radials only, drag radials permitted, must retain one of the following aspect ratios (275/50-15, 275/60-15, 255/50-16, 275/40-17, 315/35-17). Must have stock-style suspension. 4-links and ladder bars not permitted. Mini-tubbing not permitted
I know I am not legal for this class anyway, but I still dont see the advantage of a minitub.
Old 12-24-2008, 04:46 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
the point of not allowing mini tubs in the Extreme class...is how many "AVERAGE JOE" daily driver style LT1's have mini-tubs.
I agree with you there is not a direct performance increase by adding tubs.
Old 12-24-2008, 05:59 PM
vanilla89's Avatar
How come in extreme street last years rules were clear about (no converted SBC heads) and this years are not??
And,what about solid roller cam's in extreme street? I don't know many "street cars" that have solid roller cam's
Old 12-24-2008, 06:06 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
with the aftermarket casting you can get today...very few SBC casting would be considered an upgrade. Plus even if you used them the stock intake would choke them back down.
I agree there aren't many...but I do know a few. A good friend of mine has a solid roller Z28 that would fit the rules to this class. I think his best pass is a low 11. The limiting factor is not the heads or the cam...its the intake, transmission, and tire options
Old 12-24-2008, 06:28 PM
vanilla89's Avatar
i can agree with you on the cylinder heads,but a solid roller cam is more of a "race car" part.It's a proven fact that solid rollers don't last on the street.I drive my car 300 miles a week and plan on driving to the shootout and i run low 11's with a hyd roller.How many "AVERAGE JOE" daily driver style LT1's have solid roller cams?
As for the limiting factor being intake,trans and tire.I'v seen alot of 10sec car with a OD trans,alot of 9sec car on the tires listed and the stock intake ain't that bad..
Old 12-24-2008, 10:31 PM
CamaroRacing12's Avatar
its pretty bad lol
Old 12-25-2008, 12:32 AM
Z-RATED94's Avatar
Ray I can understand the safety thing for the front, but I'm talking about the rear. Thanks.
Old 12-25-2008, 01:15 AM
GIZMO's Avatar
Originally Posted by CamaroRacing12
its pretty bad lol
Lots of N/A low ten second cars out there are running the stock intake. You must have a pretty mean car to have reached the limit! LOL!!
Quick Reply: Kyle finished up the 2009 LTX Shootout website!
