Question about heads on a turbo 5.3?
Hey guys, I was wondering if It would be in my best interest to put the 241 heads I have in my garage on my 5.3 thats going in my regal, I know it will drop my compression from 9.4:1 to 9.0:1 but will that benifit me for use with pump gas? My goal is have a somewhat reliable 10 sec pump gas "street car" and I use that term sparingly as the only street time that car will see is going to local meets. I guess back to my question, to meet my goal would it be more suitable for me to run the stock 5.3 heads or would the 241 heads be better.
Any help will be appreciated.
Thanks
Thanks
Thats not a huge difference but it will help. Will you be using the stock cam? A bigger cam will bleed off some compression and probably have the about the same effect as dropping .4 compression. Thats the method I will most likely be using. it'll also sound a lot nicer with the cam.
I was going to use the z06 cam, Ive read a few people have had sucess with it in turbo applications,but if i was going to choose a different cam what would be good for a turbo application?
So, Would I be better off putting the PRC springs in the stock 5.3 heads? or would the lower compression help with the tuning aspect and if so would I gain anything with switching heads?
I have 6.0L 317 heads on my 5.3L. I think i calculated it to 8.6:1 compression. I drive mine to work all the time, all over, Drives like a dream all day long and runs decent for what it is. It sounds weak like it has 150hp driving it around town, I had people laugh at me at the track when I started it up and pulled it off my trailer.
I have a 5.3 with a zo6 cam, 317's, mls head gaskets and head studs.
I agree and disagree. The piston is weak when detonated which is in part a function of static com ratio. The lower the scr the less likely to detonate which effects the life span of the pistons, head gaskets etc.
I missed the part, that the turbo was specified? I even went back and looked.
I agree, dont let it detonate, but life happens, and reality is that people make mistakes and things change. If it never detonates, you can take your knock sensors out, or atleast 0 the knock retard in programming. Is your knock retard zero? Probably not.
Hey guys, Well I changed things up a little bit, I bought a 220/220 581/581 114 lsa cam for it, Should I throw the ported 241 heads on now since i have this cam or should I still leave it sealed up and just replace the springs and rod bolts? I wanna make over 500whp on pump gas without the use of meth, Im guessing the lower compression with the 241 heads would allow that? or no?
Thanks
Thanks
