projector project
projector project
i got my tsx projectors and want to install them in my ebay projectors,when i opened them up this is what it look like
the middle pic is the actual "projector"i guess.the tsx projectors wont fit in their as is so i have two options
1)cut the housing to fit the projectors or
2)replace the ebay projector lenses with the tsx lenses.
but can i just witch the lenses out and they work fine,thats the question?
because i was going to retrofit the tsx projectors in my stock headlight housing,but said **** it why not try to switch out the ebay projectors and if that dont work then i'll retrofit in stock housing
guess im kinda a NOOB. i always thought the projector was the same whether it was halogen or xenon. So if i were to buy a car that had projectors with halogens, and swapped out the halogens with an aftermarket HID bulb kit, it would not be as good/bright as if I had bought the car with HIDs. correct?
Copy & Paste Moderator
98MNBZ28 and I have passed back and forth some PMs about this thread. Here is some of that interaction.
No, that is just the lens. Can you take a pic of the housing with the lens removed?
Can you break down the housing further? Can the rear half of the projector be removed? If not, you'll have to cut it out. You can't mix parts. You need to use the entire TSX projector (bowl & lens).
That bowl doesn't look removable. I guess you'll have to cut it out.
Checkout http://www.hidplanet.com/forums/ for some great information on retrofits.
The reason you can't just swap the lens is because the bowl of that projector and the TSX projector are different. A projector is comprised of three main components: 1.) reflector bowl, 2.) cut-off shield, 3.) lens. The three are designed and fitted to work together.
There are some modifications you can do to projectors that involve swapping/modifying parts (usually making a custom cut-off shield or swapping a clear lens in place of a "frosted" lens or spacing the lens). Each of the modifications I hinted at are intended to alter the output of a projector for more color, sharper cut-off, etc. They are not a retrofit. A retrofit involves swapping the entire projector. In this instance, just swapping the lens would probably give you something worse than what you started with.
Originally Posted by 98MNBZ28
i have a question for you since your the light guru.i got my tsx projectors and want to install them in my ebay projectors,when i opened them up this is what it look like
http://i268.photobucket.com/albums/j...8/aug16001.jpg
http://i268.photobucket.com/albums/j...8/aug16002.jpg
http://i268.photobucket.com/albums/j...8/aug16003.jpg
the tsx projectors wont fit in their as it is so i have two options
here are some pics of the housing from the ebay projectors, they came out a little blurry but basically its just reflective material similar to the tsx projector bowl,tahst why i was curious if i can just switch the lens
http://i268.photobucket.com/albums/j...8/aug16004.jpg
http://i268.photobucket.com/albums/j...8/aug16005.jpg
http://i268.photobucket.com/albums/j...8/aug16006.jpg
http://i268.photobucket.com/albums/j...8/aug16007.jpg
http://i268.photobucket.com/albums/j...8/aug16008.jpg
I have those ebay projectors too and I have noticed with the HIDs the beam pattern is rather narrow, and I found when I was driving through some really heavy snow that I missed my old stockers with halogen bulbs because of it. But so far I only have missed the stockers during that snowstorm
this is an interesting thread. I started a thread in my local section about some that im making using C6 projectors in a stock headlight. some of my info might be helpful.
https://ls1tech.com/forums/western-m...ave-again.html
for the headlamp part i cut out the mount from the C6 and grafted it into the Camaro headlight. the high beams projector i was able to screw straight into the Camaro headlight, then seal it in. it all fits behind the lens no problem.
EDIT: I do agree that you cant just swap around parts. the main reason why you need to use the entire assembly is that the distance between the light source and the lens is crucial to getting the right cutoff and effect. the arc of the lens is designed with that distance in mind, and of course, the "bowl" is also angled with the distance in mind.
EDIT II: Ill also add that the C6 projector is the shallowest ive seen. it fits really well into the camaro housing. you might want to try and get a set to fool around with.
wow that ebay housing is very very shallow before it has to go back out of the lense
from what i comprehend, the projectors are basically like a mag light. the hid housings that come on hid cars are more focused at spreading the light than the randomly assembled ebay projectors. so instead of a wide beam of light the tsx's focus them where you actually want the light to be, kind of like focusing the beam on a mag light
um... not quite.
Halogen projectors have a narrower beam with more centralized light because halogen bulbs don't produce as much light.
HID projectors produce a wider more uniform beam because a HID capsule produces more light.
Therefore TSX HID projectors will produce a wider, brighter, more uniform beam than those ebay Halogen projectors.
dont give up. maybe my thread will give you inspiration. I am willing to help you out if you do regain interest. I just dont/didnt think that the ebay projector headlights were a good headlight to base the project off of.
