has any body used lakewood rear lca
i was looking through my jegs magazine and i notcided that lakewood makes lca but these ones are called traction action lca supposebly helps hook better any body heard of them or used them?
Didn't know that. But I didn't care for the fact that the rear of the car felt like it had no movement at all. You couldn't even push the backend down a 1/4 inch. I doubt a little play at the front of the TA would have helped that much, but maybe I'm wrong. I also started hearing of problems with the brackets breaking, so I decided against the whole idea. I do like my Spohn though, and I highly doubt I'll ever have enough HP to break that piece.
Sounds like it was in a bind. I managed 1.41 sixty foot times with mine on my Formula , but had problems with the brackets cracking (approx. 380 rwhp N/A). I switched to Pete-Z bars after that and had similar sixty foot times, but without the bracket failures. I have since gone to a BMR Extreme torque arm and non-adjustable lower contol arms.
so in other words get an adjustable TA i just need to get my car to hook im puttin a stroker motor in it in the next week or two and i have a 355 pushing like 320 and i cant even get that to hook right now i mean i have after marker panrod bar sway bars lca and a non adujstable torque arm with some comp enginereing shocks any ideas at all
Yes, you need a adjustable chassis mounted TA. Through in some good tires, like the MT street radials and go from there. It would help if you had some 15 inch rims too, more sidewall. Ditch the front swaybar for the track.
I too have the regular lakewood LCA's on my car. I originally planned on boxing my stocker's, and adding urethane bushings, but would have had a considerable amount of money in the whole deal, and still had sh*tty looking stock LCA's
not to rain on your parade or anything, but there are numerous 9sec and to a lesser amount, 8sec cars running stock-style suspension. so the Torque arm CAN be your friend.
