Dual pump install question
Is it a pain in the *** to install 2 racetronix pumps in-tank? I already have one installed with the supplied harness but will be needing to add a second pump for n2o
There are a couple of ways to do it. You could make your own, using a Y or T fitting, as in this thread: https://ls1tech.com/forums/fueling-i...ick-cheap.html , along with all the supporting h/w and wiring for a 2nd pump.
Or you could buy one pre-made from a sponsor. The only bad thing about that is that it sounds like you have to toss all the Racetronix stuff, harness AND pump. Not sure how you would feel about that.
LS1TECH Sponsor
I sell them every day....
The DIY is one option, but you need provide enough power to them & most hot wire kits are not designed for 2 pumps.
The venturi style pumps are not intended to be used in this manner & will require modifications to use with a dual intank setup.
My recommendation is to sell your existing pump/wiring to recoup most of your money & I can then set you up with a complete system that is fully assembled, tested & ready to drop in. I try to make it as easy as possible so there is no fabrication, trial & error, or hunting for parts.
Feel free to give me a call if interested in a kit.
